Page 2 of 3
Re: Raspberry 4, Debian Buster, easy2connect
Posted: Mon 3. Jan 2022, 12:24
by Henni92
ich habe das selbe Problem wie Oliver72 und lese mal mit.
Vielen Dank schonmal.
Posted: Mon 3. Jan 2022, 14:24
welche ausgaben kommen, wenn Sie den Befehl
easy2connectrefresh
ausführen?
Posted: Mon 3. Jan 2022, 16:08
by Henni92
pi@raspberrypi:~ $ sudo easy2connectrefresh
pi@raspberrypi:~ $ /bin/easy2connect: line 28: [: gt: binary operator expected
gpg: WARNING: unsafe permissions on homedir '/tmp/fipbox'
gpg: checking the trustdb
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:   1  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:   1  signed:   0  trust: 1-, 0q, 0n, 0m, 0f, 0u
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  5750  100  4366  100  1384   6263   1985 --:--:-- --:--:-- --:--:--  8249
gpg: encrypted with 4096-bit RSA key, ID 2AA41B56E7FEAB99, created 2021-12-05
      "easy2connect <support@feste-ip.net>"
grep: /proc/device-tree/model: binary file matches
/tmp/easy2connect/run.sh: line 12: /sys/class/leds//trigger: Permission denied
Stopping openvpn (via systemctl): openvpn.service.
/tmp/easy2connect/run.sh: line 21: iptables: command not found
rm: cannot remove '/tmp/easy2connect/openvpn/ec.auth': No such file or directory
net.ipv4.ip_forward = 1
/tmp/easy2connect/run.sh: line 47: /sbin/iptables: No such file or directory
/tmp/easy2connect/run.sh: line 48: /sbin/iptables: No such file or directory
/tmp/easy2connect/run.sh: line 49: /sbin/iptables: No such file or directory
/tmp/easy2connect/run.sh: line 50: /sbin/iptables: No such file or directory
/tmp/easy2connect/run.sh: line 51: /sbin/iptables: No such file or directory
/tmp/easy2connect/run.sh: line 52: /sbin/iptables: No such file or directory
/tmp/easy2connect/run.sh: line 53: /sbin/iptables: No such file or directory
/tmp/easy2connect/run.sh: line 54: /sbin/iptables: No such file or directory
/tmp/easy2connect/run.sh: line 55: /sbin/iptables: No such file or directory
/tmp/easy2connect/run.sh: line 56: /sbin/iptables: No such file or directory
/tmp/easy2connect/run.sh: line 57: /sbin/iptables: No such file or directory
/tmp/easy2connect/run.sh: line 58: /sbin/iptables: No such file or directory
/tmp/easy2connect/run.sh: line 59: /sbin/iptables: No such file or directory
knockd: no process found
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel wird dann immer weiter fortgeführt bis ich es abbreche
Posted: Mon 3. Jan 2022, 18:24
by Henni92
Die Installation von iptable hat auch noch nicht den gewünschten Erfolg erziehlt
/usr/bin/easy2connect: line 28: [: gt: binary operator expected
100  5750  100  4366  100  1384   5707   1809 --:--:-- --:--:-- --:--:--  7516
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
VPN-Tunnel ...
Posted: Tue 4. Jan 2022, 15:50
by Henni92
Problem gelöst. Falsches OS installiert. Nachdem ich Debian Buster Lite installiert hatte, funktioniert alles wie gewünscht. Danke für die Hilfe.
Posted: Mon 10. Jan 2022, 13:06
by GuideThomas
Habe selbes Problem wie Oliver72 und ähnliche Ausgaben wie bei Henni92.
Seit dem Update auf Rasbian 11 Bullseye scheint hier etwas nicht mehr zu funktionieren!
/usr/bin/easy2connect: Zeile 28: [: gt: Zweistelliger (binärer) Operator erwarte        t.
gpg: WARNUNG: Unsichere Zugriffsrechte des Home-Verzeichnis `/tmp/fipbox'
gpg: "Trust-DB" wird überprüft
gpg: Tiefe: 0  gültig:   1  signiert:   1  Vertrauen: 0-, 0q, 0n, 0m, 0f, 1u
gpg: Tiefe: 1  gültig:   1  signiert:   0  Vertrauen: 1-, 0q, 0n, 0m, 0f, 0u
100  8432  100  7048  100  1384  14622   2871 --:--:-- --:--:-- --:--:-- 17457
gpg: verschlüsselt mit 4096-Bit RSA Schlüssel, ID E2018667F6AB0E21, erzeugt 2022        -01-09
grep: /proc/device-tree/model: Übereinstimmungen in Binärdatei
/tmp/easy2connect/run.sh: Zeile 12: /sys/class/leds//trigger: Keine Berechtigung
/tmp/easy2connect/run.sh: Zeile 17: cd: /sys/block/mmcblk0/device: Datei oder Ve        rzeichnis nicht gefunden
cat: manfid: Datei oder Verzeichnis nicht gefunden
cat: oemid: Datei oder Verzeichnis nicht gefunden
cat: name: Datei oder Verzeichnis nicht gefunden
cat: hwrev: Datei oder Verzeichnis nicht gefunden
cat: fwrev: Datei oder Verzeichnis nicht gefunden
cat: date: Datei oder Verzeichnis nicht gefunden
cat: serial: Datei oder Verzeichnis nicht gefunden
cat: /sys/block/mmcblk0/size: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 21: iptables: Kommando nicht gefunden.
rm: das Entfernen von '/tmp/easy2connect/openvpn/ec.auth' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
gpg: verschlüsselt mit 4096-Bit RSA Schlüssel, ID E2018667F6AB0E21, erzeugt 2022-01-09
/tmp/easy2connect/run.sh: Zeile 68: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 69: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 70: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 71: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 72: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 73: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 74: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 75: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 76: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 77: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 78: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 79: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 80: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 81: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 82: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 83: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 84: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 85: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 86: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 87: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 88: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 89: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 90: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
/tmp/easy2connect/run.sh: Zeile 103: /sbin/iptables: Datei oder Verzeichnis nicht gefunden
knockd: Kein Prozess gefunden
VPN-Tunnel ...
VPN-Tunnel ...
Da unter Rasbian 11 Bullseye u.a. auch die RaspiCam mit MOTION nicht mehr funktioniert bin ich nun ebenfalls wieder zu Buster lite gewechselt und siehe da, alles funktioniert einwandfrei.
Es wäre schon, wenn das Team von FIP in den nächsten Monaten aber auch ein funktionierendes Script für Rasbian 11 veröffentlichen könnte.
LG
FipBox + Rasbian11 Bullseye nicht möglich?
Posted: Thu 11. Jul 2024, 09:15
by GuideThomas
Rasbian10 Buster wurde abgekündigt und es gibt keine Updates mehr.
Deshalb habe ich alle meine Raspberries gestern auf Rabian11 Bullseye upgedated und versucht, die FipBox mit dem Installationsscript dort neu aufzusetzen - ohne Erfolg!
Kann es wirklich sein, dass die FipBox unter Rasbian11 noch immer nicht läuft??
Posted: Thu 11. Jul 2024, 10:43
by WillyIP
habe gestern auch - nach vergeblichen Versuchen, meine Orginal Feste-IP SD-Card auf einem Raspi3b zum laufen zu kriegen - eine neue Installation unter Bullseye erstellt und problemlos mit dem Installationsscript zum Laufen bekommen.
Zumindest wird mir der Raspi3 mit der neuen Feste-IP easy2Connect - ID als online angezeigt, weiter bin ich noch nicht.
Ich habe Bullseye 32bit/minimal config ohne GUI genommen und lediglich openVPN mit apt-get zusätzlich installiert.
Was ist denn das Problem?
Gruß, WillyIP
Posted: Thu 11. Jul 2024, 18:23
by WillyIP
Habs jetzt getestet, d.h. über das Mobilfunknetz über VPN in mein Heimnetz reingegriffen - läuft!
Trotz der Warnings:
- das Entfernen von '/temp/easy2connect/openvpn/ec.auth' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
- gpg: WARNUNG: Unsichere Zugriffsrechte des Home-Verzeichnis '/tmp/fipbox'
- knockd: Kein Prozess gefunden
weiss jemand, was diese bedeuten? Ist das schlimm?
Gruß, WillyIP
Posted: Sun 14. Jul 2024, 09:26
by WillyIP
Aaalso - um das jetzt für mich abzuschliessen:
Habe vorgestern mit dem Support telefoniert. Der konnte meine Fragen super beantworten.
- alle 3 u.g. Warnings sind irrelevant, man kann sie ignorieren.
- die Installationsscripte von Feste-IP funktionieren derzeit (Juli 2024) bis einschliesslich Bullseye, aber NICHT für Bookworm.
Vielleicht interessiert diese Info ja jemanden ...
